right for an easy process which will leave you with good results and minimal effort get the Bilt Hamber car cleaning and care kit
» FULL CAR CLEANING AND CARE KIT
Buy Auto-wash with Auto-clay and Auto-balm, and have all three for £27.99, saving you £5.89. + FREE applicator and buffing kit worth £4.99
Please enter any quantity you require and your shopping cart will calculate the most economical rate for your order.
Quantity Unit Price
1 or more £27.99
http://www.bilthamber.com/bilthamber-special-offers.php
phone your order through and ask if you can swap the auto clay for Soft auto clay £1 up charge immsmc
read the instruction sheets and get to work (apply the balm thinner than thin wet pad dab onto balm a couple of times ((dont rub the pad into it)) Too much is a pig to remove
wash- clay- wash - balm (no need to dry car between wash and balm)
if you want to polish your car then you can
wash -clay- wash-dry- polish- balm
but you are going to have to put some time in with the polishing stage...
1ft square area will probably need a couple of "hits" of about 3 mins to make any noticeable correction..
the Balm contains fillers which will hide swirls really well
and can also be used on black trim
get the drill idea out of your head as well as that will cause more harm than good...
