Diagnostics check
  • Thread starter bigbravo
  • Start date
  • Replies 0
  • Views 310
Diagnostics check
B
bigbravo
Hi i done a diagnostics check on the car and no fault codes showed up and i also had to remove the blue temperature sensor plug because the car is just dying with it plugged in or i have to keep foot on the throttle with it plugged in to stop it dying.
Heres some readings if anyone knows more about them than i do.
Readings all are at idle
Engine speed 1100 rpm
Idle aim 1128 rpm
engine load 123 (mg/c)
advance 0.5
The cars becoming hard to start can a starter cause these symptoms.
Its also had new spark plugs and leads.
Can being gave the wrong spark plugs cause this?
If anyone has more ideas what they think could be causing it feel free to jump in.
Thank you.
M
1
323
S
N
446
NebulonB
N
B
18
2K
nedge2k
N
S
1
363
Stephen
S
