M marko79 New member Joined Dec 14, 2013 Messages 5 Points 1 Dec 14, 2013 #1 Comments to these readings please... the car is fiat brava 1.6 16v ...'96year
V varesecrazy Patron member Parked in the garage Written 10+ guides Written a review Joined Apr 27, 2011 Messages 36,914 Points 10,515 Location Near the M4 Dec 15, 2013 #2 marko79 said: Comments to these readings please...View attachment 127887 the car is fiat brava 1.6 16v ...'96year Click to expand... they are ALL in RED..!! what problem do you have?, Charlie
OP OP M marko79 New member Joined Dec 14, 2013 Messages 5 Points 1 Dec 15, 2013 #3 poor acceleration in revs to 4000rpm small twitch when giving gas
N Neverth Established member Joined Jan 18, 2012 Messages 665 Points 201 Dec 15, 2013 #4 Unplug lambda and try driving it? Maybe it is starting to die. Or the MAP sensor, check the tube from manifold to the sensor is not blocked (its in the firewall on the old ones).
OP OP M marko79 New member Joined Dec 14, 2013 Messages 5 Points 1 Dec 15, 2013 #5 lambda is new map changed the tube is clear =D
V varesecrazy Patron member Parked in the garage Written 10+ guides Written a review Joined Apr 27, 2011 Messages 36,914 Points 10,515 Location Near the M4 Dec 15, 2013 #6 is driving with map , or , Lambda unplugged the same..??, can you read any Codes..?? Charlie
B brava51 New member Joined Oct 1, 2013 Messages 14 Points 3 Dec 16, 2013 #7 Any fault codes from reader
V varesecrazy Patron member Parked in the garage Written 10+ guides Written a review Joined Apr 27, 2011 Messages 36,914 Points 10,515 Location Near the M4 Dec 17, 2013 #8 brava51 said: Any fault codes from reader Click to expand... I'm guessing obd1..
B brava51 New member Joined Oct 1, 2013 Messages 14 Points 3 Dec 17, 2013 #9 poss obd1 as obd2 is 2001 onwaeds petrol 2004 diesel BUT saying that i aquired an obd2 that does some pre 2001 cars it all depends on the car to be honest also how much you pay for your code reader as they range from £19 to £1800
