I wont beat about the bush so here goes.
Driving down the road and hear a load bang, lots of smoke and we skid to a halt 40 ft down the road.
Lower ball joint (attached to suspension wishbone) has dropped out causing the drive shaft to pop out and the wheel to turn 180 degrees+++.
Recovery mechanic manages to put it back together and I drive it home.
Front wheel is now at an angle & pointing in at the top.
Take to garage and shock is bent at top and tyre is wrecked so they sorted. £185 later and the wheel is still pointing in at the top. Fiat looked at it and they & my mechanic is still baffled as to what is causing this. It is blatenly obvious when looking at the wheel. It''s at about a 10 degree angle and you can barely fit your hand behind the top of the wheel. The mechanics advised that it may be the hub assembly that may be mishapen but they say that it shouldn't be because it is cast iron and that it would of shattered before it ever bent. They are just stumped by it. They showed me the measurements with wheels off and the hub is 1.6cm out. New hub assembly is apperently £200. Can't afford that though. The wishbone is apparently OK as well.
Just wondering if anyone could have any other ideas as to what the problem may be. Am desperate as it doesn't feel safe to drive.
