Debadging
Debadging
T
Tom
On the front side of the Bravo, beneath the indicator. I have the 1.4 12v, It came rather loose the other day when i washed it and it came of. I used white spirit to remove the glue, nice and clean. But you can just see the out line of the badge, one layer of blue missing as they sprayed it once again with the badge on. Any way of hiding this with out having the whole car resprayed...
You could try t-cutting the area spreading and polishing into the rest of the wing if it's quite a good colour match.With it being a cutting paste it should smooth out the layer difference with a bit of elbow grease.Just don't go over the top and go through to the primer as the standard paint is quite thin!
ben
J
3
172
J
8
277
David
T
8
220
J
T
2
178
MadGT
M
