Technical  De-cat and lambda sensor
Just 'cause I'm bored...I'll make the mention in case anyone reads it;
cinq/sei spi..one pre-cat lambda,...leave as is regardless...its very important
sei mpi..two lambdas. one pre-cat, one post-cat lambda...leave pre-cat its needed as above.
The post cat must remain fitted (else it'll go into limp mode), but if running a decat, block any air to the sensor. I used tin foil wrapped tightly and sealed...the lack of ANY gas tricks the car into thinking the cat is fine (y)
Kristian
