DASTEK info
DASTEK info
donnylad
right got the deposit back from the ecu company and wanted to know how mappable if at all a DASTEK would be on my hgt 147,cant really say what the spec is at the minute but defonately need to know weather fueling, ignition and air can be conteroled aswell as rev limimter set in each gear at max power so as no over reveing in each gear or is that a job for a fully customised jobby, also want to know if its possible to set the thermostat at a lower temp and weather it can controll my CRY02 kit for the inlet. and while im on the job is the 20vt oil pump batter than the hgt as it runs an oil cooler or is the hgt capable of this without loosing oil preasure
chears mi dears AAARRRGGGHHH
Rev limiter, no
Tuning in each gear, not needed, that subaru ECU didn't know what gear you were in either
Over-revving, thats down to the driver.
You DO NOT want the rev limiter set AT peak power as it will be undrivable. Plus the peak power RPM doesn't change when you change gear.
ECU has no control over the thermostat.
id luv to take the car downt to you mate but its just to far,
ive found the info on the dastek thingy aswell people.
Check out the feature list below and compare it to any other engine management upgrade - we're sure you'll be impressed.
Variable valve timing adjustment
Rev limit adjustment
Boost limit & level adjustment
Dual maps for use with different fuel grades & types
Water Injection
Nitrous oxide progressive injection
Bigger/supplementary injector handling
Variable induction control
Launch control for turbo vehicles
Full throttle gear changes
Road speed limiter removal
Speedo conversion for imports
Shift light
Idle speed stabilisation
jay where abouts are you in london?
If you change the rev-limiter on your HGT to 16,000rpm you'll be seeing ~600BHP.
(LOL) :)
dont laugh. he might. for at least a few seconds...
Buzz
The champion of the Bravo 1.4 & now ex owner of a Bravo 1.8
lol all will be revieled soon lol hahhahhahhahhaaa lol sorry bout that it was supposed to be an evil lough lol well it wont be long anyways.
B
2
568
Tommy K
T
7
848
S
M
436
M
R
2
489
R
P
7
688
S
