Technical Dashboard Removal - Air Con
tazztham
Selangor
Hi there,
My marea is having a small leak on gas in my air con system. After checking, looks like the cooling coil behind the dashboard is leaking.
The job need to remove the whole dashboard in order to change the cooling coil. :cry: Hate that.
Anyone have a diagram or service manual how to remove dashboard correctly?
Thank you.
Good Day,
Please see attached diagrams for the step by step removal of the dashboard. Please take note of those plastic screw retainers behind the dashboard they come handy during the re-assembly stage.
Cheers,
hi Belfad,
this is great info. thanks a million. ;) (y)
seems like u are having the full service manual. any change to get a copy from you? i really need it if i want to keep my marea weekend JTD for long.
Could you post a "how to" with photos, particularly issues around the driver's airbag disablement?? thanks.. :)
Good luck, sounds like a pig of a job... :eek:
Good Day,
Marea147, Please correct me you would like to disable as in remove your vehicles driver's airbag ?:confused: How to remove and replace the airbag I can help you but a word of caution those "Things" are installed there for a reason or purpose.
Cheers,
