Technical Dash lights out on ulysse
gdm75
Evening all, with luck this is an easy one!
The lights are not coming on in the center console behind the display for the climate control and associated switches, would this be a fuse & if so which one or bulbs, and if this is the case how do I get to them? Thanks for your help
Usually the bulbs, there are two both on separate circuits, one for the switch illumination and one for the LCD screen.
Prise off the plastic chrome effect strip with a screwdriver and the simply pull up the lid of the console starting from one corner to the other.
Undo the block connectors to the climate control unit and the lid will lift away enough to see the 2 bulb holders. They are not replaceable by simply inserting another bulb, the bulb and holder are one unit and cost between £3-£5 depending on where you get source them.
You can get LED ones but they give a more directional beam so don't look as good visually.
