Hi guys,
I have a 2007 Citroen Jumper 3.0. We're converting it into a camper and one of the things I've put in is a Votronic DC-DC charger for our lithium leisure battery.
It's working fine, but it's working in voltage mode. Meaning it will start charging the battery whenever it senses +13.2V or so on the starter battery, indicating the alternator is running.
It can also run in 'intelligent' mode, which has the additional benefit that it will charge the other way around, charging the starter battery from the leisure battery which is also charged by solar.
To make it run in intelligent mode, I need to connect D+, a signal that will tell the DC-DC charger if the alternator is running. I'm wondering if I have this kind of connection somewhere on this van. Some people suggested connecting to the ACC signal, but this would put a load on the starter battery before starting the engine...
