turbospec
Good evening all, We have a fiat croma turbo diesel here that cut out on the owner several times until one day it refused to start, scanner produced fault code relating to the fuel pressure regulator which we replaced, still no start, we now have fault code P0778 which is fuel pressure high pressure pump inlet/output injector support. We checked the fuel pump which is not priming the common rail, putting power direct to the pump works it fine but, even with pump running the engine still wont start and still produces the same fault code:bang::bang:, any ideas boffins???
