Hi Granville.
I've been doing some more digging and enquiries and found the following.
1) Very nice Vauxhall Service guy confirmed that Vectra 'C'/Signum did/do have a natural high rear tyre wear. There was a campaign to the rear geometry but did'nt make much of a dent in the rear tyre wear issue. Basically rears will probably wear at the same rate as the fronts or slighly slower. Would not give a mileage
2) He checked the actual Vauxhall instructions for adjusting rear toe and camber and there are no instructions to replace the blots. On lots of their procedures there are important notes when bolts are required to be replaced. NOT for rear tracking.
3) Spoke a lenght to a Micheldever tracking bay technician and he confirmed that they have never replaced bolts. Also double checked their adjustment computerised instructions and again no mention of replacing the bolts.
4) Commented on the Croma rear negative camber spec. as being quite high. In my case he thinks my high negative camber and excessive toe could be counteracting each other and hence my apparent even wear across the tyre.
5) SNAP!
I tow a caravan as well
Are you saying that Fiat have done the campaign on your car but you still have excessive tyre wear? Also is the tyre wear similar to mine. i.e. high but fairly even? Did Fiat actually adjust your car or just say tyre wear is withing spec.
I've got to follow up with my dealer next week. I spoke to the service manger today and he said they do replace the bolts and were aware of the parts shortage/omission wrt bolts in the bulletin. A technician also confirmed that the two stage process is to check the tyre wear and ONLY if it is excessive, as per the supplied data (which only looks for ourside to inside differences), are they allowed to then go and make adjustments.
I'm thinking of going my own way and paying the £60 to get a full 4 wheel alignment done. I'm also thinking of largely ignoring the Fiat values and going for the extreme limits of the ranges. Basically going for near zero camber and near zero toe and then see what happens.
Nick /////
5) SNAP!
Nick /////
