JohnCamper
- Joined
- Jul 18, 2020
- Messages
- 34
- Points
- 11
My Ducato is a 2016 F1AE3481D 2.3 130 Multijet. The timing tool kit I have has two Cam locking pins which measure 10mm diameter. These fit the camshafts perfectly. They are quite precise, slight rocking of the cams is required to allow the pins to drop into their respective holes. The holes in the cam covers which have the removable plugs screwed in, are also 10mm diameter, so when the pins are in place there is no movement. Why there seems to be a difference is a puzzle to me as the genuine Fiat tool number 99360614 is constant across many years. All I can think is that occasionally there may be pins made by cheap producers which are very slightly oversize and are not a good fit???
Hi Tiger, we have the same engine (mine is 2013), so it is a little confusing.
Others have found the same problem.
The cam locking pins will not even allow me to screw them in because the pins simply will not push/drop in far enough to allow thread engagement. I measured the pins with a simple gauge, which showed 10mm, and no amount of wiggling or engine movement would make any difference.
I removed probably close to 1mm of material from one pin and it now fits ok, there is virtually zero cam movement, so I'm happy, although I also believe that my cam-locking pins are also too long, as even when fully engaged they do not drop in all the way to the circlip.
Anyway, all good so far. The new belt kit should arrive tomorrow, so I've cleaned up the whole engine bay above and below ready for re-assembly.
Buycarparts.co.uk is where I bought the (Gates) belt kits, and they have been so slow. A week and a half so far, then I discovered the bits were coming from Germany!!!!!! If only I had known.
