Technical  cooling fan problome
SIMONGURL
HI I have a 2007 ducato 2.3 with a problem with the secondary cooling fan ,can anyone tell me where the relays are and also the fuse for the fan/relays are ,i do not have a hand book and all fuese under the stearing wheel are ok
One of the problems I have found with the ducato cooling fans is the commutator in the motor (the copper strips the brushes act on) tarnish up as exposed to the elements beacause of the ventilation holes in the motor frame. Easy method to clean up is just to rotate the fan by hand, (with power OFF or disconnected for safetly). It can take a lot of turning but eventually you get enough of a connection for it to run. Once running it cleans itself up very quickly when powered.
