Technical Coolant temp sensor location
Hi guys as above can anyone tell me where the temp sensor is located on the grande punto? Pic would be great..also what type sensor is it as i have been told there is 2?
Did a search and it seems this is at fault as temp needle stays low and have the eml on now and then when it happens.
Many thanks
Many thanks
what engine?
FAQs has some good pic layouts
Passenger side of engine on side of block integrated into thermostat. You'd be as well just changing thermostat, fairly quick and easy on 1.2 / 1.4 8v and comes with new sensor
Cheers mate. Is it where the coolant hose from the rad runs into the engine? Quick look an the sensor seems to be yellow in colour..is tgis the correct one? Ones i have seen online are green and brown.
Hi Gpmo.
If you take a look at a thread I had one here a few months ago I have some pictures of the thermostat from a 1.2 8v which may help you, replacing the part was easy too if you want to go down that route.
Here
I had a leak in my thermo housing and was causing me to lose coolant like there's no tomorrow.
As you can see from the pics the thermo sensor on mine was green.
Maybe you might find some of the info in that post useful?
Thanks and good luck! (y)
Ghandimate you are a star. Thats helped massively. Touch would thers no leaks the temp needle seems to sit low and a few times its dropped and eml light has popped up too after a quick search it seems the sensor might be the issue here...i hope.
Thanks again.
Me again bumping an old thread...
Is this (the bit with the yellow clip) hiding the coolant temp sensor? I think based on the helpful diagram above it's actually an air temp sensor that's attached to the coolant temp sensor?
https://imgur.com/XaodrTE
Any tips for removing it? So far I've gotten the yellow clip out :p
Looks like it is ...
BRs, Bernie
If someone here helped You fix -or better, understand- your issue, hit the thanks icon @ bottom right corner, it's free and makes us feel helpy ;-)
Hey
Yes you are right that is the temp sensor. But again agree with above.you may want to consider changing thermostat also, easy enough just take time I did mine literally weekend gone so fresh in my mind lol. With the clip u need to pull the yellow clip back and then it should reveal under it a bouncy black part that u push down on to release. Just take time and just wiggle it left and right whilst pulling backwards gently. Also be car full putting back on I slightly deformed mine .20190913_144200.jpeg
Hey
Yes you are right that is the temp sensor. But again agree with above.you may want to consider changing thermostat also, easy enough just take time I did mine literally weekend gone so fresh in my mind lol. With the clip u need to pull the yellow clip back and then it should reveal under it a bouncy black part that u push down on to release. Just take time and just wiggle it left and right whilst pulling backwards gently. Also be car full putting back on I slightly deformed mine .View attachment 203120
I may just go ahead and return the coolant temp sensor and buy the whole unit (including thermostat). I have the MAP sensor to fit this evening which I suspect will get the car running again, but keen to replace the coolant temp sensor too since that was the error code I had/have.
Thanks again for taking the time to reply.
Yeah no worries. I changed it on a punto tjet and if I can do it on that engine anyone can. The choice is yours in the end but I changed my thermostat and radiator hose cz there was a small leak where the too met, so decided to flush whole system. Change radiator hose and the thermostat and fresh antifreeze .
Would be a good idea to replace parts one at a time, just to confirm your error code is related to one or the other sensor ...
BRs, Bernie
BRs, Bernie
That's the plan! The MAP sensor has been swapped and didn't fix anything, so coolant temp sensor next. Had a go at removing the air temp monitor from it this evening and failed. Also, does anyone know the socket size required to remove the coolant temp sensor?
So, my understanding is that the air temp sensor is plugged into the coolant temp sensor? I need to unplug the air temp sensor, and then use a long socket over the top of the coolant temp sensor?
Sorry but I can hardly follow you. What do you mean by "air temp sensor" ? There is no such a think in itself !
Air temperature is measured at two places: one in the airflow meter (ECU needs both intake air volume AND temperature to compute the A/F ratio) and the other is in the Manifold Air Pressure sensor.
The one hidden behind the "yellow lock connector" is the coolant temperature sensor; disconnect the plug and you'll get to it, possibly a long socket will help...
BRs, Bernie
I get what you mean. But not the sensor (yellow and black connector we have been on about that is connected to the coolant temp sensor is purely what gives the coolant temp sensor its power. Its not another sensor on top. Just see it as the power switch so you know in your car if your car has a problem with it or not. So you simply disconnect it and then use a long socket over the temp sensor t9 remove that.
I can't remember the socket size at the min but I'm working with my car tomorr9w and can check for you on the old one I took off.
