Technical Connecting Car To MultiECUScan
Short version:
Can anyone recommend an ELM327 USB connector for my laptop please?
P.S. I already have all the coloured adaptors, just need the connector.
Longer version:
I bout a VAG/KKL connector to use with multiecuscan only belatedly to discover it does not support the GP. DOH! :bang:
However due to a shipping mix up the seller refunded me, so I'm not out of pocket and I have all 6 coloured adapters to boot. :D
Just need a decent ELM connector now and I'm away.
Thanks,
Thomas
This is what the spec is:
About the OBDLink SX interface
Features the new STN1110 chip
The STN1110 chip supports the full ELM327 command set and an extended command set adding many enhanced features
The STN1110 is up to 10 times faster than the ELM327 chip
4 times as much flash memory as ELM327 chip
Over 5 times the RAM of the ELM327 chip
The STN1110 is Firmware updateable while the ELM327 requires the chip to be replaced with each new version
Here are a couple of ELM327s on eBay:
ELM OBD2 CAN FIAT ALFA DIAGNOSTIC LEAD FOR use with MULTIECUSCAN - https://www.ebay.co.uk/itm/223147151416
Compatible Fiat Alfa Lancia diagnostic ELM 327 OBD2 interface fits Multiecuscan - https://www.ebay.co.uk/itm/281166266540
ELM 327 MODIFIED DIAGNOSTIC CABLE for use with MULTIECUSCAN FIAT ALFA LANCIA - https://www.ebay.co.uk/itm/301626849586
All from the same seller (business address), £14.95, £15.95 and £16.95 respectively.
I bought one from this seller about 2 years ago, though not the same listing (mine was a bundle including additional cables). Works fine.
In the interests of balance here are a couple from another UK seller:
New ALFA FIAT DIAGNOSTIC CABLE ELM OBD2 CAN ECU MODIFIED For Multiecuscan - https://www.ebay.co.uk/itm/272718545703
ELM MODIFIED DIAGNOSTIC CABLE FIAT ALFA LANCIA AIRBAG ABS CAN MULTIECUSCAN - https://www.ebay.co.uk/itm/263143936422
£14.99 and £17.99 respectively.
Ordered the Gendan OBDSXLink. Emailed them and I've got a bundle with a multi ECU scan and licence coming.
Already got all 6 adaptors so I should be up and running soon.
