Hi peeps....just after some advise for heat shield/proofing of cone filter on mk1 bravo....but could relate to any car with cone fitted.
Here's a pic of my current set up.
Plan on replacing filter with a jetex cotton cone which seems to have good write ups.
http://www.fastcar.co.uk/2012/05/04/performance-car-air-filter-test/7/
Do like the ITG foam jobbie but too impractical.
But want to provide a decent cold air flow and offer some heat protection at same time.
Cold Air flow first: Easy option is to use standard air feed from above radiator and pipe to filter and also thought about using the inner arch vent but popping a little filter over it.
Another option was popping the N/S fog light out and using that as cold air feed as its well away from engine heat, but could also be put back to factory at a later date if needed.
Heat shield: The filter is well placed in the wing but still open to heat soak from the engine. I want to construct a heat shield enclosure in the wing but unsure of what material to use.
After a search found Aluminium based material...
http://www.nimbusmotorsport.com/ProdShop.asp?category=252
Used on engine bay side of wing and on front under bonnet stay clip to enclose the filter. With cold air feed fed through from both front of car and inner wheel arch vent.
Loads of heat proofing on market but wanted something rigid that i could form rather than the stick on stuff....any left thought i might try make a form of my ex manifold heat shield too.:yum:
Is there anything else worth doing while at it, lagging rest of intake pipes etc....
Have a stainless magnex system and FCperformance chip also fitted. Just thought the next step would be to scavenge a miniscule amount from efficiency.
http://strikeengine.com/air-filter-heat-shields-3
Just after ideas what else is out there or what other people have done.
Cheers for taking time to trawl through all that.
