coffeebean500
- Joined
- Jul 20, 2019
- Messages
- 27
- Points
- 7
Hi all,
First time posting about my Ducato (I also have a 500). Purchased a 2012 3.0 180 Multijet to convert to a campervan. Let it mostly sit over the Swedish winter and that was a big mistake. Went to drive this spring and now have been dealing with a bunch of problems. First I had to deal with brake issues, then replace the fuel filter, then there was a short somewhere in the rear lights. Got those solved but I have a persistent engine light on with code P0262 (high voltage injector 1). The van starts fine and drives for a bit before the light kicks on and I guess it must go into "limp home" mode....and that's what I do. I took it to the local garage and they gave it back with no charge, said they don't think it is a bad injector, but that I should take it to the dealer and see about getting the ECU updated and/or flashed. I called the dealer and, without seeing the car, they quoted me about 1200 USD to replace injector 1 as that was "99.9% likely" to be the issue. Of course.
I think it is some electrical issue. I've dealt with crazy Christmas trees on my 500, and already solved some minor shorts and things with the van. So...today I decided to take apart every connector I could find under the hood, clean everything, check grounds, re-tape wires where needed, etc. I found a mystery connection hanging out over by the ECU. It appears to be a different mystery connector than the post from a couple of days ago, it looks like the same type of connection the EGR uses so I thought maybe it COULD be important, but I cannot find where it goes. Since I don't post much, I cannot post a photo or link here, but I did upload to imgur: /a/Y8y9nuO If anyone can tell me what it might be, that would be great, I cannot seem to solve this with my wiring diagrams. I realise it is probably from some option I don't have, but when you are looking for an electrical issue and you find a connector waggling about by your ECU, you wonder.
Happy to hear any suggestions about the error as well. I have read a ton of forum threads, here and elsewhere, trying different solutions. Will get the dealer to flash/update the ECU this coming week but I am trying to be proactive about the issue.
