After trying everything I know (changing vacuum hoses, inlet manifold gasket, injector O rings and afew other bits an bobs I've cleaned up and ressembled and a general looks about) my mk2 uno turbo still won't idle when its cold.
when cold it still runs between gears, but if you pull up or stop at a junction is cuts out unless I have a few rev's going.
once warm it runs like a dream, just when cold it struggles to idle and stinks of fumes.
I think the cold start is A problem, it kicks down the idle way too soon (like 7-10seconds, wheras I think it should be more like 1-2mins!!!)
Or possibly ecu/injectors dying.
the flapper box seems to be working fine as once warm it idles and goes right throughout the rev range smoothly and without fuss.
anybody know if you can replace the cold start valve?
