Technical code reader
freelanderuk
hi all
can anybody point me in the direction to get a code reader or set up the software on my laptop and buy the lead , i have found the 3pin adapters on ebay and the free fiat scan program but need to no which other lead i need.
any help would be great
cheers
chris
thanks Dave , had seen that post but i am unsure if i just buy the 3pin adapter lead then have to buy a lead that plugs into the laptop
cheers
thanks Dave , have now ordered the leads and downloaded the software .
thanks
chris
thanks for your help Dave , i got all the leads and tried the software and i have error code P0480 cooling blower motor malfunction , this code will not clear , any ideas how to rectify please
cheers
chris
thanks Dave :),
i have just been running the engine and the warning light goes of then comes back on then off for a while and carries on like this off/on etc when the engine gets warm, could this be a sticking relay?
i used the fiatscan software and got the fan running on the drivers side but not the one on the passsenger side, are they numbered from the passenger side
cheers
chris
I still have this problem of the injection light on for code P0480, the light is on all the time , i have connected 12volt to the fan direct and it runs ( so not a faulty fan ) i have swapped the relays behind the cover on the radiator and still have the same problem , where is the sensor for the tempreture to turn the fans on any can any body give me any other ideas to try , its been to a garage for 4 hours with no joy
thanks
chris
Fiat garage?
How about some vehicle details?
hi
its a 2002 ducato 2.8jtd
i have checked the relays and then they are both ok , i have connected 12v to the fan and it runs, i have checked the fuses and can not find a blown one , i have thought about getting the temp sender replaced to rule out that,
i live in a little village and the nearest fiat dealer is 80 miles away , the garage i took it to is the one i use for servicing which has diagnostics but could get no futher
thanks
chris
hi
thanks
chris
Relays are activated by grounding in the ecu.
Measure resistance between pin 19 of the ecu connector (yellow I think) and positive.
Measure resistance between pin 20 of the ecu (grey/black I think) and positive.
