Clutch & Wiper problems
dan
hi once again lads, right couple of questions, first i was wondering about my clutch when im ni a high rev and attempt to change gear the clutch pedal sticks and coesnt engage when i lift my foot up, wtf is going on, it only takes a split second car revs for a sec then the cltuch engages and everything is hunky dorry. also any ideas why my rear windscreen wiper clcks every so often, brava 1.4sx 1996.
***TITLE ADDED***
Re: Untitled
wiper motor dodgy, take it off give it a clean bit of lube and should be orite.
Re: Untitled
with the clutch, is there a rattle at about 1,800 2,000 revs? hold it round that area 4 a few seconds and listen, plus, when u press the clutch pedal down, can u hear a sort of knocking sound?
no knocking of any sort it feels like its getting stuck on the carpet but i havnt got any so its not that
i kno wot u mean, um check the clutch arm, if not most likey inside clutch lookin at £150 plus
Sticky pedal - check the clutch slave cylinder or steel cable.
If its not one of the above - its the clutch pressure asembly
Members Site - - - - - - - My Site
re clutch
I got to go with Sven on this one. it's not going to go away. get it done before you are stranded
750
Dark Lurker
I
2
1K
Dark Lurker
J
3
778
Dark Lurker
M
2
435
S
