Technical Clutch Pedal
Malta
Hi again.
Another problem guys. The clutch pedal is very wobbly. It doesnt stay straight like the brake pedal for example. My VRT test is soon and I need to fix this problem before I take it. Any suggestions of how to make not wobble anymore?
Thanks.
You are right guys. The bushes. Now can you please tell me the procedure of how to replace these bushes? :confused:
It seems a bit complicated...!
Thanks.
Here's a picture.
I've never had to do it, but I think you disconnect the clutch and throttle at the pedals, remove the bolt (arrowed red) remove the pedal(s) and replace the bushes.
FIAT dealer for bushes or, failing that, any little engineering place will make you some up in an engineering plastic (nylon, PTFE, etc.) or a suitable bronze alloy.
