General Clutch Pedal Squeak
coldhamlodge
Hi
I have a ducato 2.8jtd 2003 18 maxi I have a strange click and then squeak as I depress the clutch pedal have looked but can’t find what’s causing it, I need a diagram if possible of the clutch pedal assembly so I can see what’s in there and try and work it out, of if someone has already solved this problem a hit of what to do.
Thanks in advance
Keith
Sorry can't help with a suggestion of what might be wrong but Freespirit has provided a link to the eLearn workshop manual for the 2.8JTD (in Downloads, top of the header page) which will have a picture of the clutch assembly.
The procedure for downloading has been covered in quite a few threads so if unsure you could search for this.
hi
yes but i have a apple mac book pro so not sure they work on there i will have to find out
Keith
Hi
attached are some diagrams of the clutch pedal assembly for your reference
thanks for that FreeSpirit helped loads
have found little pin 2a has come out will try and put it back and see what happens
thanks again Keith
hi and ya it worked so no more squeak or click job done thanks agin for your help freesprit will have to keep my eye on it to make sure it does not come out again
Keith
