Clutch...need a straight answer ..not contradicting ones..
Dianne
hi my clutch is constantly rising and its near a point when the biting point is at the top..
now i hear two things on this forum
they say that the cltuch cable cannot be adjusted meangn a whoel new clutch is reqd
secondly the simpel solution is that it need to be bled that is all??
what is going on
i have a 1.2sx
and need a good answer of what to do
what parts to buy and rough idea of labour costs
do i need to buy a whoel clutch kit\?
if so why..if all it need is to b adjusted or bled???
sorry if i seem angry..but im not just a stright answer i need
saves me hassle of beign in two minds
thanks to those who did give the right answer to several cluthc questiosn on this..
i changed my clutch slave cylnder a month ago so i have done this part already..
There is no clutch cable, it is all hydraulic.
Check the brake fluid reservoir, if it is low you have a leak somewhere, as they use the same fluid reservoir.
Then get it bled and see what the outcome is.
Hope that helps :)
SEX...I'm just two women short of a Threesome
Those answers don't look contradictory to me...they're just multiple solutions for what you're problem COULD be. We can only give you 100% confident answers by experiencing your specific problem first hand.
My advice to you would be start at the cheapest/easiest option and work down the list.
People usually offer cheaper alternative solutions, hence why some say buy a new 3 piece clutch and others say check the master and slave cyliners and possibly bleed the fluid through with new fluid.
Theres a lot that can cause similar problems, normally cheap fixes solve the problem which means you dont need to pay out alot of money on something you dont need. For example, if you replaced the clutch and still had the same problem you would be mighty angry for paying over £200 for a new clutch.
Its always best unless it obvious to try the cheaper alternative first, or atleast rule out the cheaper possibilities of not being the cause of the fault.
Designed by Italians, Driven by Enthusiasts
See my Ebay Items here.
HI I CHECKED THE BRAKE FLUID
IT SEEM PERFECT TO ME
I REMEBER WHEN IT WAS TOPPED AND THERE HASNT BEEN ANY MOVEMENT SINCE
WHAT WILL BE THE NEXT STEP
THANK to the replies
sorry for caps
liek i said i needed clearing up
sorry if it didnt seem this way.
if the brake fluid level as far as your aware hasnt moved since the new slave cylinder has been fitted then you need a new clutch
when you say the biteing point is high, when you release the clutch do you get any slip... as in you put your foot down at say 30mph in 5th gear, do the revs just go up and no momentum picked up or is there no slip? easiest way to test this is to start the car, put it in 4th gear an try pulling away with the hand break well on, so your pulling against it. if the revs build and the car doesnt stall the clutch needs replacing
for a garage to replace the clutch aswell as supplying you are looking at around £200 if you can find somewhere that will do the work (i had massive trouble finding someone that would work on my 1.2 because it was a Fiat) avoid Mr Clutch at all costs, they are uselss inept cowboys that charge going rate if not more for sub standard parts and labour
the 1.2 is easy to do the clutch on, i did mine last week, getting the gearbox off is no real issue and theres more than enough space in there to move around
Andy_sx
NO SLIPPPING
IT DEFO STALLS..
now what lol
cheers for the reply..
bleed the clutch system. possible air trapped inside or a leak..
re
i agree with bleeding the system, if it got low or while the master cylinder was changed then you coudl of trapped some air, better to have it bled than spend mega bucks on new clutch then find out it only needed bleeding.
M
7K
mick gibbons
M
P
15
12K
Dark Lurker
924
David
M
2
447
S
