uncle stewie
- Joined
- Jun 2, 2009
- Messages
- 6
- Points
- 4
We have a 2000 JTD Multipla - great car, carries all six of us in comfort, had it about 18 months, went to Monaco via Switzerland Sept last year - great car for family touring but two problems cropped up then which have just cropped up again. Lengthy description coming up... anyone any thoughts?
In the alps, doing a downhill on a very hot day, we had the engine warning ligth come on and the engine refused to rev or pull away. Sit tight for ten minutes and start her up and we were off OK. This happened again after hitting a nasty pt hole too. Since then fine. But this has happenend again twice in the last week - once after sitting the drive all day, once on the school run in the afternoon - eight months since the last flash....? Again sit tight for ten minutes or so and she starts up again and keeps going - but twice in one week is a worry.
In Monaco traffic in 38 degrees we found the clutch getting stiffer and stiffer - its pretty stiff all the time and only frees/bites just off the floor since we had it, but we really had to push it into gear until it would not go in any gear - unless you turned off the engine, slip it nicely in, turn on and away you go. OK in the snail pace traffic in Monaco, more of an issue in faster moving traffic, but after crawling out of the jams, she ran nicely and after parking up for a few hours and doing the beach she set off back to the site no problem at all....... in slow traffic on the motorway in Italy a similar stiffness started to develop but disappeared as soon as the traffic flowed again?
Think this sounds like a clutch needing to be replaced - none of the fluid levels are an issue, no slipping, no judders, and she ran fine once moving....? But I noticed when looking at the car when its EMU light came on this week that the clutch became very stiff, esp into reverse and kept knotching the gears.....
Are these two issues related or is it bad news all round - if the clutch is on its last legs after all this time, can the engine pick it up in some way and trigger the warning light...... when we first had it serviced the garage suggested that an air flow meter sensor may be out - but no other problems at all other than a short period of glow plug light flashing for 20 seconds after starting last March - which just went away - and some suspension problems - arms, swing bearings, main spring etc - which we expected!
Any suggestions before we venture out in to garage land .... want to avoid re-mortgaging!
