If you have too little movement at the pedal the damage that could happen would be that the clutch plates are still connecting drive from the flywheel as you depress the pedal and change gear. You would cause extra wear and overheating with the clutch components.
The gears will tend to be carrying on spinning with greater inertia making them more likely to crunch..more damage.
All this will tend to put a strain on the gear-change linkages and cause additional stress damage there.
Altogether making very good additional reasons to get it just right as you have.
