Technical  Clutch bleed
shaun
Established member
United Kingdom.
Hi, has anyone bled there clutch as my biting point is very low. This is the bleed valve which is different than the tjet one shown in Elearn
Thanks Shaun
That looks like a perfect bleeding nipple so you can bleed it there.
But... I'm guessing you didn't just do some work on that system, it worked fine but the problem started.
Bleeding it would just make it temporarily better but won't be a fix. Looks like there is fluid leaking.
Thanks for the reply Mike1alike. I will bleed it from there if that doesn't cure it it looks like a new clutch
It's a slightly better pedal now I have bled it but I think i need a new one and I my as well fit a clutch at the same time
Thanks again Mike1alike
