Technical Clutch bite almost on the floor
hello, Ours was excatly the same, when i took the gearbox off the pressure plate fingers were broken, only option is a new clutch.
Hello, Clutch is quite time consuming, as the front sub frame needs to be lowered to get the gearbox off, Took me about a day on and off.
the system is a bugger to bleed
mine stayed low after replacing the MS but after two revese bleeds it climbed
ok at the mo but i agree they wear out generally at about 60k
good luck
nick
