General  Clonking
General  Clonking
If it's definitely from the rear, most likely culprit is one of the Sub-frame mountings (bushes).
Front pair seem to go more often than the rears.
Jack the car up at the back, but not anywhere on the suspension or sub-frame, and see if the sub-frame can be moved away from he chassis, lever it with a large screwdriver or flat bar.
If it's really loose, it may move down under it's own weight, so best to get someone else to do the jacking while you watch each side, don't stick your head under there though.
Ok thanks I'll try jacking the back up tommrow. The noise is deffenatly from the rear as I've had clonking noises from the front before so I no it's from the rear as it only happens when the rear wheels go over things
Hi
I also have a cloncking on the offside rear. It sounds sometimes like everything is ready for dropping off! Then it stops and I don't hear it for a while I have jacked it up and everything looks ok although the sub frame on that side looks a bit closer to the body than the other one, not being a trained mechanic I don't really know what a knackered mounting bush looks like??
Any one help?
Malc
These are healthy mountain bushes
images
They look a little dry Slobo, they could do with some lube I reckon :D
Anyway, this is what your Subframe looks like . . .
The rear bushes (1) rarely seem to go, I think that's because they're mostly only subjected to upwards loading, whereas the fronts (not numbered) get a constant up and down pounding from bumps, dips and braking.
The bushes are basically rubber blocks, with a metal sheath and a metal core.
The sheath is what's pressed into the bores on the Sub-frame, and the core is where the mounting bolts (8 & 12) clamps them to the chassis.
There are also large cup washers (not shown) fitted under the bolt heads, that are larger than the bores in the Sub-frame, so that even if the bushes completely fall apart, the Sub-frame can't physically detach from the chassis.
If you jack the car up at the back, not on the trailing arms or the Sub-frame, then the Sub-frame is hanging on the bushes.
There should be no relative movement between the Sub-frame and the Chassis, other than the mm or so due to the flexibility of the Rubber.
You can get a flat bar or large screwdriver in-between the Chassis and Sub-frame, and try to lever the Sub-frame downwards.
Any movement, either the bush moving in the Sub-frame, or the bush and Sub-frame moving together in relation to the Chassis, means a new bush is needed.
Thanks thats great just the extra detail I was after, I will check it out. And get back to you.
Slobo don't give up your day job!
Malc
Dose any body no if you can just buy the rubber bushes,or do you have to buy the sub frame.
and how much.
mel
just gone on to ebay and found ziggy-a2z back and front bushes for the back subframe.
£107 free post.
mel
many thanks bikedoc
Like I mentioned, I'd be surprised if the rear ones are shot, have you checked?
Should be able to buy just the fronts from a few sources.
Edit; Just had a look at their site.
Says for the front ones . . . " *** will need slight modification " . . . but doesn't say what.
Probably need turning down by a few thou on the outside, that's the norm for non-fiat Bushes, usually Vauxhall items.
You'll need a Lathe, or need to know someone that has one.
I'd contact the seller and get that clarified before you order.
rear ones are ok and i think the front ones are ok to.
The nose is just on one side, the passenger side.
Had a screw driver in between the Chassis and Sub-frame and i am sure they are ok,
Had a look at the wheel and it seems to be out of line,and when i go around corners i get the nose to. any help on this please.
thanks
Mel
thanks
Mel
I sometimes get the nose as well.
