Technical Clock Adjustment
Chester
Hi Everyone. I've just bought a 2018 1.4 Easy Plus and am very pleased with it. Only problem is I can't change the time on the dashboard clock. I've followed the handbook instructions but the Settings menu seems to be missing several of the items that should be there, including the date and time.
Am I missing something or is there a fault in the menu system?
Are you checking on the radio or dashboard menus
I know on the higher end trim cars its all on the radio not sure about on the basisc Radio fitted to the easy
Thanks for the advice Chris. There is a simple menu screen in the settings option on the radio that let's you adjust the clock and the other 'missing' options that the handbook says are available from the steering wheel buttons! Easily done when I found it.
