clock adjust
clock adjust
T
Tom
Anyone tell me how to change the clock on the Brava? It's all part of the integrated stereo and I haven't got the handbook. Loads of buttons with letters on - is it the CDC+ and the CDC- ones? I have tried pressing them but no joy?
What year, i.e. Mk1 or Mk2 radio?
Mark.
Council estate lad.
And proud of it!
Member of the Guild of Experienced Motorists.
clock
mark 2. turn on radio, press an hold rnd button until it beeps and expert a ppears let go and tm comes on. adjust clock using the volume control. press and hold rnd until it goes back to normal
spot on
Just done it mate - spot on. I'd NEVER have worked that one out myself. Many thanks.
clock
Glad i was able to help, had the same problem, 2 weeks i was at it and only found out by accident
code
Big Al, does your stereo have a code? Is there any way of finding out if mine does or not? (apart from disconnecting it). If it does, what otions do you reckon I have got if or rather when it eventually needs to be cranked up again? It doesn't actually say anything about it being coded anywhere on the outer casing.
hold the expert button, move through the options, if thescreen says "safe" i think, then the code is active, if moving through the options it says, "code" then its not active so can remove and replace without having to enter the code. I dont have a code for mine and was worried when swopped the stereo, but luckily mine code isnt active
code
Thanks ant - when you say the expert button do you mean the rnd button?
re radio code
First ,the rnd is printed under the exp button, the latter being on the button itself so they are the same button.Re radio code, I have had my battery off and it did not affect the radio. I too do not have the code. If you get stuck with the code there are plenty of places that will find the code for you, mobile as well. Cost about £15
code
Thanks Al.In other words - worst case scenario, £15. Nothing much to worry about then.
C
2
403
M
L
1
479
A
A
5
311
M
A
13
465
A
M
6
324
M
