Technical  Climate control
cliffy71
Hi guys ,iv got the common problem of a broken flap actuator, mines the main face vent one ,iv bought and fitted a new ferrule off eBay and I am ready to re-fit the actuator.
My question is do I have to fit it with the flaps in a certain position ( mine are currently closed ) how does the car know which position the flap is in ? Any help or advice would be grateful before I break the new ferrule thankyou
Was a doddle in the end ,sorted all working,thanks for all your help and advice !!
Hey Cliffy71!
I couldn't help you, because I still haven't changed that annoying thing! I tried to fix it, but no luck.
So, right now you have more experienc with this, so you can answer these questions:
"My question is do I have to fit it with the flaps in a certain position ( mine are currently closed )?
How does the car know which position the flap is in?"
No is the answer,just ,fit then turn IG on then press both center buttons on panel to do the Calbration thing ,I now have face air vents ,easy
I also soaked and cleaned the potentiometer in contact cleaner and turned it in the cleaner ,a fair bit of muck came out ,I mark original position before turning it
