Ok All you stilo gurus i need your help. im having a major problem with my climate control. im getting major cold air on the left hand side and very hot on the right side. I assume its probably a distribution motor. the thing is though, which one? because i am confused.
The top left side as your sitting in the car of the climate unit is for the windshield vent of what i figured out. right below it i assume controls the middle and bottom flaps. The outside air is in between the tunnel all the way in the back.
Where is the dualzone flap which i assume is responsible for the major temp diff of each side?
BTW i have already tried doing the relearn procedure but it aint working. (also noted my top windshield motor is not working probably a plastic connector but i havent had time to deal with it yet i dunno if this is affecting the relearn process for the dualzone as well)
Also while trying to figure out which motor is the problem i found this plug coming from behind the ashtray and have no idea where its suppose to be connected. i do see though that it shares the same wire loom as the ash tray light. i looked it up in elearn and found the ashtray light is connector G35 but couldnt figure out what the other connector was i think but not sure its the aerial for the jkeyless entry? (which i dont have btw)
