J
Jonah
My girlfriend's Bravo ('99 1.2) has a small problem somewhere in the front suspension. Whenever you accelerate, decelerate or brake, there is a single sharp "click" that sounds like it's coming from around the passenger footwell. It makes one click when you start to accelerate, and one when you start to decelerate (with the brake pedal or engine braking in lower gears) - so it's as if something is shifting one way under forward loads and the other way under backwards loads. Whatever it is, it's not just "loose" as nothing rattles over the bumps, and the accel / decel needs to be above a certain threshold before it makes the noise.
I've had a look around the NSF suspension and can't find anything obvious... all the suspension clamp bolts, wishbone brackets and subframe mounting bolts are nice and tight and I can't feel any play in anything. Although it's difficult to put any large forces on anything just using hand tools.
Any ideas what else it could be?
Thanks,
Jonah
Thanks,
Jonah
