- Joined
- May 16, 2011
- Messages
- 49
- Points
- 18
Citroen relay with the puma engine, same as the Ducatotonight on the way home engine management light come on and it started revving up on its own,so out of control i nearly hit the car in front
its belching out black smoke like its really over fueling,its under warranty,but the vans a 06 newshape so getting on a bit ,place we bought it its under warranty for another 3 months,it died last week and there code reader said its a egr fault,so they cleaned it,it was fine for 3 days now doing it again,its smoking so bad with the revving up on its own i thought the engine was going to blow,but it stops revving up if i turn the ignition off,its not running on sort of ruling out the turbo,the garage dont know whats causing it,i have read a valve can collapse :?: on the fuel rail and it will need to see a main dealer for a update to solve the issue wise does anyone know whats going on with the van?
