Technical Cinquecento weights ->
clubgeneration
Heerenveen
When you want to make your car lightweight you can use this handy (incomplete) summary.
Great guide for weight reduction and/or weight distribution.
Input from other users is always appreciated, I'll keep this post updated.
My native language is Dutch, so it's possible that you're encountering difficulties reading some part names.
Small parts weighted with a digital kitchen scale.
Big parts weighted with a digital bathroom scale.
All parts weighted without screws, bolts, rings and/or nuts (unless otherwise specified)
Cinquecento - weights (last update: 17/01/16)
A-pillar (apiece) = 195 g = 0,20 kg
A-pillar (per set) = 390 g = 0,39 kg
Air intake (resonance chamber) = 143 g = 0,14 kg
Antenne (incl. rubber / excl. nut & cable) = 48 g = 0,05 kg
B-pillar - cover scuff plate / floor carpet (apiece) = 34 g = 0,03 kg
B-pillar - cover scuff plate / floor carpet (per set) = 69 g = 0,07 kg
Battery box = 90 g = 0,09 kg
Belt (rear - middle) = 426 g = 0,43 kg
Blower motor (excl. housing) = 874 g = 0,87 kg
Blower motor (incl. housing) = 1260 g = 1,26 kg
Bodykit - Abarth - rear bumper = 4800 g = 4,8 kg
Bodykit - Abarth - sideskirt (apiece) = 1350 g = 1,35 kg
Bodykit - Abarth - sideskirt (per set) = 2700 g = 2,70 kg
Bodykit - Abarth - front bumper (incl. fog lights) = 6700 g = 6,70 kg
Bodywork - rear bumper - Sporting = 3000 g = 3,00 kg
Bodywork - hatch (excl. window / rubber) = 7400 g = 7,40 kg
Bodywork - rear window (excl. rubber) = 3000 g = 3,00 kg
Bodywork - rear window rubber = 1000 g = 1,00 kg
Bodywork - hood = 7600 g = 7,60 kg
Centre console - Sporting = 628 g = 0,63 kg
Charcoal canister = 600 g = 0,60 kg
Charcoal canister - mounting bracket = 535 g = 0,54 kg
Cover - belt - rear - (apiece) = 77 g = 0,08 kg
Cover - belt - rear - (per set) = 154 g = 0,15 kg
Cover - ignition coils = 100 g = 0,10 kg
Cover - fuel pump = 315 g = 0,32 kg
Cover - ECU fuse = 60 g = 0,06 kg
Cover - steering column = 169 g = 0,17 kg
Cover - inertia switch = 95 g = 0,10 kg
Dashboard = 5000 g = 5,00 kg
Dashboard - ashtray = 195 g = 0,20kg
Dashboard - cigarette lighter - holder = 29 g = 0,03 kg
Dashboard - cigarette lighter - plug = 33 g = 0,03 kg
Dashboard - dials - 900 = 735 g = 0,74 kg
Dashboard - dials - Sporting = 790 g = 0,79 kg
Dashboard - casing (?) dials & heater controls = 900 g = 0,90 kg
Dashboard - instruction manual (incl. folder) = 795 g = 0,80 kg
Dashboard - speaker cover (apiece) = 26 g = 0,03 kg
Dashboard - speaker cover (per set) = 52 g = 0,05 kg
Dashboard - switch (apiece) = 17 g = 0,02 kg
Dashboard - vent - center = 237 g = 0,24 kg
Dashboard - vent - driver side = 115 g = 0,12 kg
Dashboard - vent - passenger side = 115 g = 0,12 kg
Door container (apiece) = 490 g = 0,49 kg
Door container (per set) = 980 g = 0,98 kg
Door light switch (apiece) = 9 g = 0,01 kg
Door light switch (per set) = 18 g = 0,02 kg
Door panel (apiece) = 700 g = 0,70 kg
Door panel (per set) = 1400 g = 1,40 kg
Door stop latch (incl. bolts) (apiece) = 233 g = 0,23 kg
Door stop latch (incl. bolts) (per set) = 466 g = 0,47 kg
ECU / computer - 1.1 8v F2 = 644 g = 0,64 kg
Exhaust - end silencer - Sporting (incl. bend) = 6000 g = 6,00 kg
Exhaust - mid silencer - Sporting (incl. flexible section) = 2220 g = 2,22 kg
Exhaust - ophangrubber (apiece) = 70 g = 0,07 kg
Exhaust - header - Sporting = 3760 g = 3,76 kg
Exhaust - header - air intake connection = 104 g = 0,10 kg
Floor carpet - trunk = 800 g = 0,80 kg
Foot rest - driver side = 211 g = 0,21 kg
Fuel flap (incl. hinge) = 100 g = 0,10 kg
Gearbox - lever weight (excl. 2 bolts) = 205 g = 0,21 kg
Gearbox - lever weight (incl. 2 bolts) = 237 g = 0,24 kg
Gearbox - reverse lock release cable = 131 g = 0,13 kg
Gearbox - shifter boot = 82 g = 0,08 kg
Gearbox - shifter casing - Sporting = 695 g = 0,70 kg
Gearbox - shifter casing - 900 = 740 g = 0,74 kg
Handle - hatch = 33 g = 0,03 kg
Handle - door (apiece) = 212 g = 0,21 kg
Handle - door (per set) = 424 g = 0,42 kg
Handle - roof - front (passenger side) = 106 g = 0,11 kg
Handle - roof - rear (apiece) = 106 g = 0,11 kg
Handle - roof - rear (per set) = 212 g = 0,21 kg
Heat shield - exhaust (foremost/ above cat) = 708 g = 0,71 kg
Heat shield - exhaust (middlemost / above midpipe) = 508 g = 0,51 kg
Heat shield - exhaust (back / above mid silencer) = 609 g = 0,61 kg
Heat shield - exhaust (fore- / middlemost / rear) = 1825 g = 1,83 kg
Hose - cooling - radiator (upper connection) = 195 g = 0,20 kg
Hose - header -> air intake = 127 g = 0,13 kg
Insulation (battery) = 182 g = 0,18 kg
Insulation (topside both doors) = 450 g = 0,45 kg
Insulation (bottomside both doors) 450 g = 0,45 kg
Insulation (top- & bottomside both doors) = 900 g = 0,90 kg
Insulation (floor & tunnel) = 4000 g = 4,00 kg
Immobilizer - transponder (incl. ring) = 72 g = 0,08 kg
Intake - header - Cinquecento = 1295 g = 1,30 kg
License plate light (apiece) = 52 g = 0,05 kg
License plate light (per set) = 104 g = 0,10 kg
Locking mechanism - inside - hatch = 170 g = 0,17 kg
Locking mechanism - cylinder lock - hatch = 100 g = 0,10 kg
Mount / aluminum instead of rubber (custom) - engine = 473 g = 0,47 kg
Mount / rubber - engine = 420 g = 0,42 kg
Mount / rubber - gearbox (rear) = 490 g = 0,49 kg
Mount / rubber - gearbox (UK passenger side) = 811 g = 0,81 kg
Mount / steel - engine = 1274 = 1,27 kg
Mount / steel - gearbox (UK passenger side) = 474 g = 0,47 kg
Mounting bracket - cowl panel = 330 g = 0,33 kg
Mounting bracket - cooling hoses - cowl panel = 130 g = 0,13 kg
Mounting bracket - ECU = 520 g = 0,52 kg
Mounting bracket - end silencer / tow hook / rear bumper = 1325 g = 1,33 kg
Mounting bracket - engine bay / air intake / wiring = 182 g = 0,18 kg
Mounting bracket - horn = 188 g = 0,19 kg
Mounting bracket - MAP sensor = 123 g = 0,12 kg
Protector shield (drive shaft) = 420 g = 0,42 kg
Pulley - crankshaft - 1108cc 8v SPI = 565 g = 0,57 kg
Rear panel incl. ashtray (UK driver side) = 660 g = 0,66 kg
Rear panel (UK passenger side) = 620 g = 0,62 kg
Rear panel (both sides) = 1280 g = 1,28 kg
Roof lining = 2700 g = 2,70 kg
Rubber - drain heater matrix = 110 g = 0,11 kg
Rubber - paravan (?) / hood = 246 g = 0,25 kg
Rubber - roof strip (apiece) = 240 g = 0,24 kg
Rubber - roof strip (per set) = 480 g = 0,48 kg
Scuff plate (apiece) = 235 g = 0,24 kg
Scuff plate (per set) = 470 g = 0,47 kg
Seat - back (sitting) = 5900 g = 5,90 kg
Seat - front (apiece) = 15200 g = 15,20 kg
Seat - front (per set) = 30400 g = 30,40 kg
Side mirror (incl. inside panel) (apiece) = 570 g = 0,57 kg
Side mirror (incl. inside panel) (per set) = 1140 g = 1,14 kg
Sound deadening - back seat = 102 g = 0,10 kg
Sound deadening - dashboard = 9000 g = 9,00 kg
Sound deadening - hood = 540 g = 0,54 kg
Sound deadening - cowl panel / engine bay = 1600 g = 1,60 kg
Sound deadening - tunnel / gear shifter = 2600 g = 2,60 kg
Sound deadening - floor - 4 pieces = 660 g = 0,66 kg
Spare wheel (standard 135/70R13) = 9500 g = 9,50 kg
Spare wheel accessories (car jack / etc.) = 2416 g = 2,42 kg
Starter - Sporting = 3220 g = 3,22 kg
Steering stalks (incl. wiring harness) = 360 g = 0,36 kg
Strut cover (apiece) = 75 g = 0,08 kg
Strut cover (per set) = 150 g = 0,15 kg
Sun visor (apiece) = 205 g = 0,21 kg
Sun visor (per set) = 411 g = 0,41 kg
Swaybar - Sporting = 3100 g = 3,10 kg
Swaybar - rubbers & accessories = 1074 g = 1,07 kg
Swaybar - rubbers, accessories & bar = 4174 g = 4,17 kg
Throttle body (upper part / incl. injector & rubber) = 430 g = 0,43 kg
Throttle body - 38 mm = 709 g = 0,71 kg
Throttle body - 40 mm = 686 g = 0,69 kg
Throttle body spacer - 38 mm = 77 g = 0,08 kg
Throttle body spacer - 40 mm (incl. 1 gasket & hole strengtheners) = 77 g = 0,08 kg
Timing tensioner = 174 g = 0,17 kg
Timing tensioner - insert = 39 g = 0,04 kg
Tow hook - rear = 262 g = 0,26 kg
Tow hook - front = 460 g = 0,46 kg
Tow hook - front & rear = 722 g = 0,72 kg
Vent (behind rear bumper) = 120 g = 0,12 kg
Wheel arch liner (apiece) = 1000 g = 1,00 kg
Wheel arch liner (per set) = 2000 g = 2,00 kg
Window guides (per set / door) = 178 g = 0,18 kg
Window guides (both doors) = 356 g = 0,36 kg
Windshield washer pump (apiece) = 99 g = 0,10 kg
Windshield washer pump (per set) = 198 g = 0,20 kg
Windshield washer reservoir (excl. washer pumps) = 370 g = 0,37 kg
Windshield wiper - passenger side (incl. wiper) = 330 g = 0,33 kg
Windshield wiper - rear (incl. wiper) = 127 g = 0,13 kg
Windshield wiper motor - rear = 950 g = 0,95 kg
Wiring harness hatch (incl. contact breakers) = 130 g = 0,13 kg
Added to the FAQ :)
Is it possible that since you've added this post to the FAQ-section, I'm unable to edit my first post? I can't find the 'edit' button anywhere? :confused:
I do see the 'edit' button at this post, so something must be changed with the above one...
Don't think you can edit a post after someone has posted a later reply.
So your "Edit" button should have gone from your last post too now.
Nope, still there! :p
I want to keep the first post updated, if possible...
Kinda strange if I've to post new additions on the bottom of the thread... :confused:
Must be a time thing then.
But your "Edit" button will disappear at some point.
Never seen it before on a forum... :bang: Thanks anyway!
So, for everyone, hereby the updated list! :slayer:
Cinquecento - weights (last update: 23/01/16)
Bodywork - fender (apiece) = 2120 g = 2,12 kg
Bodywork - fender (per set) = 4240 g = 4,24 kg
Locking mechanism - steering column (incl. mounting bracket) = 982 g = 0,98 kg
Mounting bracket - fender (apiece) = 120 g = 0,12 kg
Mounting bracket - fender (per set) = 240 g = 0,24 kg
Hereby the updated list!
Cinquecento - weights (last update: 19/02/16)
Charcoal canister - vacuum valve = 119 g = 0,12 kg
Cover - seat belt - rear - (apiece) = 77 g = 0,08 kg
Cover - seat belt - rear - (per set) = 154 g = 0,15 kg
Cover - fuse box = 69 g = 0,07 kg
Mount / steel - gearbox - lower (UK passenger side) = 474 g = 0,47 kg
Mount / steel - gearbox - upper (UK passenger side) = 999 g = 1,00 kg
Mounting bracket - immobilizer / transponder = 75 g = 0,08 kg
Rubber - steering wheel hub - Abarth = 58 g = 0,06 kg
Throttle body - injector (orange / IWM 523 00) = 54 g = 0,05 kg
Throttle body - spacer - 38 mm = 77 g = 0,08 kg
Throttle body - spacer - 40 mm (incl. 1 gasket & hole strengtheners) = 77 g = 0,08 kg
Throttle body - upper part (incl. injector & rubber) = 430 g = 0,43 kg
Cinquecento - weights (last update: 25/02/16)
Antenna (incl. rubber / excl. nut & cable) = 48 g = 0,05 kg
Brake booster = 1790 g = 1,79 kg
Heater housing (inc. heater radiator / ex. heater blower) = 3200 g = 3,20 kg
Heater housing (inc. heater radiator & heater blower) = 4460 g = 4,46 kg
Hose - cooling - expansion tank (<- throttle body) (incl. corresponding hose clamps) = 87 g = 0,09 kg
Hose - cooling - heater radiator (lower = <- 4-split) (incl. corresponding hose clamps) = 107 g = 0,11 kg
Hose - cooling - heater radiator (upper = -> throttle body & -> intake header) (incl. corresponding hose clamps) = 230 g = 0,23 kg
Cinquecento - weights (last update: 02/03/16)
Bodywork - bumper - front - Abarth (incl. fog lights) = 6700 g = 6,70 kg
Bodywork - bumper - rear - Abarth = 4800 g = 4,8 kg
Bodywork - bumper - rear - Sporting = 3000 g = 3,00 kg
Bodywork - hatch (excl. spoiler & third brake light) (excl. window & rubber) = 7400 g = 7,40 kg
Bodywork - hatch (incl. spoiler & third brake light) (excl. window & rubber) = 8600 g = 8,60 kg
Bodywork - sideskirt - Abarth (apiece) = 1350 g = 1,35 kg
Bodywork - sideskirt - Abarth (per set) = 2700 g = 2,70 kg
Bodywork - wheel arch liner (apiece) = 1000 g = 1,00 kg
Bodywork - wheel arch liner (per set) = 2000 g = 2,00 kg
Brakes - brake booster = 1790 g = 1,79 kg
Drivetrain - Flywheel - 1108cc 8v SPI = 6600 g = 6,60 kg
Engine - ECU / computer - 1108cc 8v SPI F2 = 644 g = 0,64 kg
Engine - pulley - crankshaft - 1108cc 8v SPI = 565 g = 0,57 kg
Engine - starter - Sporting = 3220 g = 3,22 kg
Engine - timing tensioner = 174 g = 0,17 kg
Engine - timing tensioner - insert = 39 g = 0,04 kg
Engine bay - cover - ECU fuse = 60 g = 0,06 kg
Engine bay - cover - ignition coils = 100 g = 0,10 kg
Engine bay - plastic battery box = 90 g = 0,09 kg
Exhaust - mounting rubber (apiece) = 70 g = 0,07 kg
Fuel system - charcoal canister = 600 g = 0,60 kg
Fuel system - charcoal canister - mounting bracket = 535 g = 0,54 kg
Fuel system - charcoal canister - vacuum valve = 119 g = 0,12 kg
Fuel system - fuel flap (incl. hinge) = 100 g = 0,10 kg
Heating - blower motor (excl. housing) = 874 g = 0,87 kg
Heating - blower motor (incl. housing) = 1260 g = 1,26 kg
Heating - heater housing (inc. heater radiator / ex. heater blower) = 3200 g = 3,20 kg
Heating - heater housing (inc. heater radiator & heater blower) = 4460 g = 4,46 kg
Ignition - Panda (incl. vacuum advance unit) (excl. distributor & rotor) = 736 g = 0,74 kg
Insulation (below heater housing) = 184 g = 0,18 kg
Intake - bob - Palio = 150 g = 0,15 kg
Intake - header - Cinquecento - 1108cc 8v SPI = 1295 g = 1,30 kg
Intake - resonance chamber = 143 g = 0,14 kg
Intake - throttle body - 38 mm = 709 g = 0,71 kg
Intake - throttle body - 40 mm = 686 g = 0,69 kg
Intake - throttle body - injector (orange / IWM 523 00) = 54 g = 0,05 kg
Intake - throttle body - spacer - 38 mm = 77 g = 0,08 kg
Intake - throttle body - spacer - 40 mm (incl. 1 gasket & hole strengtheners) = 77 g = 0,08 kg
Intake - throttle body - upper part (incl. injector & rubber) = 430 g = 0,43 kg
Interior - A-pillar (apiece) = 195 g = 0,20 kg
Interior - A-pillar (per set) = 390 g = 0,39 kg
Interior - B-pillar - cover scuff plate / floor carpet (apiece) = 34 g = 0,03 kg
Interior - B-pillar - cover scuff plate / floor carpet (per set) = 69 g = 0,07 kg
Interior - belt - rear - middle = 426 g = 0,43 kg
Interior - centre console - Sporting = 628 g = 0,63 kg
Interior - cover - fuse box = 69 g = 0,07 kg
Interior - cover - fuel pump = 315 g = 0,32 kg
Interior - cover - inertia switch = 95 g = 0,10 kg
Interior - cover - seat belt - rear - (apiece) = 77 g = 0,08 kg
Interior - cover - seat belt - rear - (per set) = 154 g = 0,15 kg
Interior - cover - steering column = 169 g = 0,17 kg
Interior - dashboard = 5000 g = 5,00 kg
Interior - dashboard - ashtray = 195 g = 0,20kg
Interior - dashboard - cigarette lighter - holder = 29 g = 0,03 kg
Interior - dashboard - cigarette lighter - plug = 33 g = 0,03 kg
Interior - dashboard - dials - 900 = 735 g = 0,74 kg
Interior - dashboard - dials - Sporting = 790 g = 0,79 kg
Interior - dashboard - casing (?) dials & heater controls = 900 g = 0,90 kg
Interior - dashboard - instruction manual (incl. folder) = 795 g = 0,80 kg
Interior - dashboard - speaker cover (apiece) = 26 g = 0,03 kg
Interior - dashboard - speaker cover (per set) = 52 g = 0,05 kg
Interior - dashboard - switch (apiece) = 17 g = 0,02 kg
Interior - dashboard - vent - center = 237 g = 0,24 kg
Interior - dashboard - vent - driver side = 115 g = 0,12 kg
Interior - dashboard - vent - passenger side = 115 g = 0,12 kg
Interior - door container (apiece) = 490 g = 0,49 kg
Interior - door container (per set) = 980 g = 0,98 kg
Interior - door panel (apiece) = 700 g = 0,70 kg
Interior - door panel (per set) = 1400 g = 1,40 kg
Interior - floor carpet - trunk = 800 g = 0,80 kg
Interior - foot rest - driver side = 211 g = 0,21 kg
Interior - handle - door (apiece) = 212 g = 0,21 kg
Interior - handle - door (per set) = 424 g = 0,42 kg
Interior - handle - roof - front (passenger side) = 106 g = 0,11 kg
Interior - handle - roof - rear (apiece) = 106 g = 0,11 kg
Interior - handle - roof - rear (per set) = 212 g = 0,21 kg
Interior - rear panel incl. ashtray (UK driver side) = 660 g = 0,66 kg
Interior - rear panel (UK passenger side) = 620 g = 0,62 kg
Interior - rear panel (both sides) = 1280 g = 1,28 kg
Interior - rubber - steering wheel hub - Abarth = 58 g = 0,06 kg
Interior - scuff plate (apiece) = 235 g = 0,24 kg
Interior - scuff plate (per set) = 470 g = 0,47 kg
Interior - seat - back (sitting) = 5900 g = 5,90 kg
Interior - seat - front (apiece) = 15200 g = 15,20 kg
Interior - seat - front (per set) = 30400 g = 30,40 kg
Interior - sun visor (apiece) = 205 g = 0,21 kg
Interior - sun visor (per set) = 411 g = 0,41 kg
Locking mechanism - hood (excl. cable & lever) = 159 g = 0,16 kg
Locking mechanism - hood (incl. cable & lever) = 328 g = 0,33 kg
Mirrors - side mirror (incl. inside panel) (apiece) = 570 g = 0,57 kg
Mirrors - side mirror (incl. inside panel) (per set) = 1140 g = 1,14 kg
Miscellaneous - antenna (incl. rubber / excl. nut & cable) = 48 g = 0,05 kg
Miscellaneous - door light switch (apiece) = 9 g = 0,01 kg
Miscellaneous - door light switch (per set) = 18 g = 0,02 kg
Miscellaneous - door stop latch (incl. bolts) (apiece) = 233 g = 0,23 kg
Miscellaneous - door stop latch (dincl. bolts) (per set) = 466 g = 0,47 kg
Miscellaneous - handle - hatch = 33 g = 0,03 kg
Miscellaneous - protector shield - drive shaft = 420 g = 0,42 kg
Miscellaneous - roof lining = 2700 g = 2,70 kg
Miscellaneous - spare wheel (standard 135/70R13) = 9500 g = 9,50 kg
Miscellaneous - spare wheel accessories (car jack / etc.) = 2416 g = 2,42 kg
Miscellaneous - tow hook - rear = 262 g = 0,26 kg
Miscellaneous - tow hook - front = 460 g = 0,46 kg
Miscellaneous - tow hook - front & rear = 722 g = 0,72 kg
Miscellaneous - vent (behind rear bumper) = 120 g = 0,12 kg
Mount / aluminum - engine (custom) = 473 g = 0,47 kg
Steering - steering stalks (incl. wiring harness) = 360 g = 0,36 kg
Suspension - bump stops (rubber stop, plastic mount, bolt & rings) - rear (apiece) = 146 g = 0,15 kg
Suspension - bump stops (rubber stop, plastic mount, bolt & rings) - rear (per set) = 292 g = 0,29 kg
Suspension - springs - rear - APEX 30-5010 (- 30 mm) (apiece)= 2098 g = 2,10 kg
Suspension - springs - rear - APEX 30-5010 (- 30 mm) (per set)= 4196 g = 4,20 g
Suspension - springs - rear - Eibach 3011-002 (- 10-15 mm) (apiece) = 1942 g = 1,94 kg
Suspension - springs - rear - Eibach 3011-002 (- 10-15 mm) (per set) = 3884 g = 3,88 kg
Suspension - strut cover (apiece) = 75 g = 0,08 kg
Suspension - strut cover (per set) = 150 g = 0,15 kg
Suspension - swaybar - Sporting = 3100 g = 3,10 kg
Suspension - swaybar - rubbers & accessories = 1074 g = 1,07 kg
Suspension - swaybar - rubbers, accessories & bar = 4174 g = 4,17 kg
Windows - window - rear (excl. rubber) = 3000 g = 3,00 kg
Windows - window - rear (incl. rubber) = 4000 g = 4,00 kg
Windows - guides (per set / door) = 178 g = 0,18 kg
Windows - guides (both doors) = 356 g = 0,36 kg
Windows - rubber - rear = 1000 g = 1,00 kg
Wipers - motor - rear = 950 g = 0,95 kg
Wipers - washer pump (apiece) = 99 g = 0,10 kg
Wipers - washer pump (per set) = 198 g = 0,20 kg
Wipers - washer reservoir (excl. washer pumps) = 370 g = 0,37 kg
Wipers - washer reservoir (incl. washer pumps) = 568 g = 0,57 kg
Wipers - wiper - front - passenger side = 330 g = 0,33 kg
Wipers - wiper - rear = 127 g = 0,13 kg
Wiring - harness - hatch (incl. contact breakers) = 130 g = 0,13 kg
Cinquecento - weights (last update: 17/03/16)
Bodywork - fender - mounting bracket (apiece) = 120 g = 0,12 kg
Bodywork - fender - mounting bracket (per set) = 240 g = 0,24 kg
Bodywork - hatch (excl. spoiler & third brake light) (excl. window & window rubber) = 7400 g = 7,40 kg
Bodywork - hatch (incl. spoiler & third brake light) (excl. window & window rubber) = 8600 g = 8,60 kg
Bodywork - hatch rubber = 1100 g = 1,10 kg
Bodywork - hood - hinge (UK driver side) (incl. support) = 431 g = 0,43 kg
Bodywork - hood - hinge (UK passenger side) = 265 g = 0,27 kg
Bodywork - hood - hinge (per set) (incl. support) = 696 g = 0,70 kg
Brakes - brake pressure differential valve - mounting bracket = 150 g = 0,15 kg
Brakes - handbrake - cable = 1050 g = 1,05 kg
Brakes - handbrake - cover (under car) (excl. nuts & rings) = 123 g = 0,12 kg
Brakes - handbrake - cover (under car) (incl. nuts & rings) = 132 g = 0,13 kg
Brakes - handbrake - lever (incl. wheel) (excl. bolts & rings) = 737 g = 0,74 kg
Brakes - handbrake - lever (incl. wheel, bolts & rings) = 801 g = 0,80 kg
Cooling - hose - expansion tank (<- throttle body) (incl. corresponding hose clamps) = 87 g = 0,09 kg
Cooling - hose - heater radiator (lower = <- 4-split) (incl. corresponding hose clamps) = 107 g = 0,11 kg
Cooling - hose - heater radiator (upper = -> throttle body & -> intake header) (incl. corresponding hose clamps) = 230 g = 0,23 kg
Cooling - hose - radiator (upper connection) = 195 g = 0,20 kg
Engine bay - ECU / computer - 1108cc 8v SPI F2 = 644 g = 0,64 kg
Engine bay - ECU / computer - mounting bracket = 520 g = 0,52 kg
Engine bay - horn = 308 g = 0,31 kg
Engine bay - horn - mounting bracket = 188 g = 0,19 kg
Engine bay - MAP sensor - mounting bracket = 123 g = 0,12 kg
Engine bay - rubber - drain heater matrix = 110 g = 0,11 kg
Engine bay - rubber - paravan (?) / hood = 246 g = 0,25 kg
Fuel system - filler flap (incl. hinge) = 100 g = 0,10 kg
Heating - heater housing (incl. heater radiator / excl. heater blower) = 3200 g = 3,20 kg
Heating - heater housing (incl. heater radiator & heater blower) = 4460 g = 4,46 kg
Intake - hose - (header -> air intake) = 127 g = 0,13 kg
Interior - A-pillar - above dashboard (apiece) = 195 g = 0,20 kg
Interior - A-pillar - above dashboard (per set) = 390 g = 0,39 kg
Interior - A-pillar - under dashboard (apiece) = 76 g = 0,08 kg
Interior - A-pillar - under dashboard (per set) = 152 g = 0,15 kg
Interior - belt - front - passenger (incl. bolts & rings) = 850 g = 0,85 kg
Interior - belt - rear - side (incl. bolts & rings) (apiece) = 1003 g = 1,00 kg
Interior - belt - rear - side (incl. bolts & rings) (per set) = 2006 g = 2,01 kg
Interior - dashboard - fuse box - cover = 69 g = 0,07 kg
Interior - dashboard - fuse box - exterior = 69 g = 0,07 kg
Interior - dashboard - mounting bar = 2100 g = 2,10kg
Interior - seat - rear - back = 8400 g = 8,40 kg
Interior - seat - rear - sitting = 5900 g = 5,90 kg
Interior - seat - rear - unlock lever (apiece) = 175 g = 0,18 kg
Interior - seat - rear - unlock lever (per set) = 350 g = 0,35 kg
Locking mechanism - hatch - inside hatch = 170 g = 0,17 kg
Locking mechanism - hatch - lock striker plate (?) (incl. bolts & rings) = 169 g = 0,17 kg
Locking mechanism - hatch - lever (incl. cable, bolts & rings) = 496 g = 0,50 kg
Locking mechanism - hatch - complete = 835 g = 0,84 kg
Miscellaneous - rubber - roof strip (apiece) = 240 g = 0,24 kg
Miscellaneous - rubber - roof strip (per set) = 480 g = 0,48 kg
Miscellaneous - spare wheel accessories (car jack / etc.) = 2471 g = 2,47 kg
Miscellaneous - tow hook - front - mount = 340 g = 0,34 kg
Miscellaneous - tow hook - front, front mount & rear = 1062 g = 1,62 kg
Mounting bracket - rear window shelf (apiece) = 180 g = 0,18 kg
Mounting bracket - rear window shelf (per set) = 360 g = 0,36 kg
Wipers - washer - pump (apiece) = 99 g = 0,10 kg
Wipers - washer - pump (per set) = 198 g = 0,20 kg
Wipers - washer - reservoir (excl. washer pumps) = 370 g = 0,37 kg
Wipers - washer - reservoir (incl. washer pumps) = 568 g = 0,57 kg
Cinquecento - weights (last update: 20/03/16)
Fuel system - inertia switch (excl. bracket, nuts & screws) = 45 g = 0,05 kg
Fuel system - inertia switch (incl. bracket, nuts & screws) = 192 g = 0,19 kg
Fuel system - inertia switch - cover = 95 g = 0,10 kg
Cinquecento - weights (last update: 05/04/16)
Bodywork - hatch - gas strut (apiece) = 349 g = 0,35 kg
Bodywork - hatch - gas strut (per set) = 698 g = 0,70 kg
Bodywork - hatch - rubber = 1100 g = 1,10 kg
All parts weighted without screws, bolts, rings and/or nuts (unless otherwise specified).
Cinquecento - weights (last update: 02/05/16)
Interior - door handle (apiece) = 39 g = 0,04 kg
Interior - door handle (per set) = 78 g = 0,08 kg
Interior - rubber - pedal (clutch / brake) (apiece) = 13 g = 0,01 kg
Interior - rubber - pedal (clutch / brake) (per set) = 26 g = 0,03 kg
Locking mechanism - door - lock knob (incl. stalk) (apiece) = 25 g = 0,03 kg
Locking mechanism - door - lock knob (incl. stalk) (per set) = 50 g = 0,05 kg
Miscellaneous - door stop latch (incl. bolts) (per set) = 466 g = 0,47 kg
Windows - window - side - front (excl. rubbers) (apiece) = 3500 g = 3,50 kg
Windows - window - side - front (excl. rubbers) (per set) = 7000 g = 7,00 kg
Cinquecento - weights (last update: 09/05/16)
Cooling - fan = 1054 g = 1,05 kg
Cooling - fan (incl. bracket, bolts & rings) = 1651 g = 1,65 kg
Cooling - fan - bracket (excl. bolts & rings) = 570 g = 0,57 kg
Cooling - fan - bracket (incl. bolts & rings) = 597 g = 0,60 kg
Locking mechanism - door (incl. lock knob, stalk, bolts & rings) (apiece) = 372 g = 0,37 kg
Locking mechanism - door (incl. lock knob, stalk, bolts & rings) (per set) = 744 g = 0,74 kg
Locking mechanism - door - door stop latch (incl. bolts) (apiece) = 224 g = 0,22 kg
Locking mechanism - door - door stop latch (incl. bolts) (per set) = 448 g = 0,45 kg
Locking mechanism - door - door handle (incl. cylinder lock & bolts) (apiece) = 184 g = 0,18 kg
Locking mechanism - door - door handle (incl. cylinder lock & bolts) (per set) = 368 g = 0,37 kg
Cinquecento - weights (last update: 19/05/16)
Engine - thermostat (excl. spring assembly & rubber) = 120 g = 0,12 kg
Gearbox - shifter casing - Seicento (excl. lever) = 521 g = 0,52 kg
Gearbox - shifter casing - Seicento (incl. lever) = 574 g = 0,57 kg
Interior - pedal - box (incl. 3 pedals / excl. rubbers) = 1878 g = 1,88 kg
Interior - pedal - box (incl. 3 pedals & rubbers) = 1904 g = 1,90 kg
Interior - pedal - rubber (clutch / brake) (apiece) = 13 g = 0,01 kg
Interior - pedal - rubber (clutch / brake) (per set) = 26 g = 0,03 kg
Cinquecento - weights (last update: 14/06/16)
Cooling - radiator (excl. vent hose) = 1202 g = 1,20 kg
Cooling - radiator (incl. vent hose) = 1272 g = 1,27 kg
Cooling - radiator - vent hose = 70 g = 0,07 kg
Cooling - reservoir (incl. cap) (excl. bracket, rings & nuts) = 640 g = 0,64 kg
Cooling - reservoir (incl. cap) (incl. bracket, rings & nuts) = 829 g = 0,83 kg
Cooling - reservoir - bracket (excl. rings & nuts) = 150 g = 0,15 kg
Cooling - reservoir - bracket (incl. rings & nuts) = 189 g = 0,19 kg
Engine - alternator - 1108cc 8v SPI = 4700 g = 4,70 kg
Engine - MAP sensor - 1108cc 8v SPI = 34 g = 0,03 kg
Engine - spark plug wires - 1108cc 8v SPI = 216 g = 0,22 kg
Exhaust - catalytic converter - Sporting (incl. lambda sensor & connector) = 3840 g = 3,84 kg
Exhaust - mid silencer - mounting bracket = 254 g = 2220 g = 2,22 kg
Lighting - indicator - side (apiece) = 14 g = 0,01 kg
Lighting - indicator - side (per set) = 28 g = 0,03 kg
Wipers - motor - front (incl. mechanism) = 2020 g = 2,02 kg
Wipers - wiper - front - driver side = 340 g = 0,34 kg
Wipers - wiper - front - passenger & driver side = 670 g = 0,67 kg
