if the highest and lowest dry figures are within 10% it is good head gasket and valves.
google compression test
the head can be skimmed several times and still be non interference so you can snap a cam belt at 5000 rpm and just replace the belt
there are marks on the casting if you mill beyond the markers you need to be very careful when replacing belt and replace on time or mileage religiously if you snapped a belt it would be bad.
the head can be milled for high compression and max power in a tuned engine ignoring these marks for non interference
if you also fit a high lift cam you need to do measurements
