Technical Cinquecento doesn't like changing gear....
marktoby2449
Hi all, so the gear change in my 1995 reluctant to say the least. Sometimes it won't find a gear, other times it won't come out of a gear. The photo attached (if I've done this right) is of the lever that seems to get stuck. What would be my best course of actions here? Cheers all.
Is your clutch adjusted correctly?
Hi, now, I have no idea, but the clutch feels ok, actually feels like it's working properly, there is however a metal sound sometimes happens as the clutch is full pressed down.
Adjustment may help, but it does sound like something is worn out if it's making a scraping metal noise.
Most likely the release bearing, but if you are taking the box off, you may as well stick a new complete clutch kit in
