Hello to all, here i have a 1995 Fiat Cinquecento with a bit of a running problem, i was driving along in 4th gear when all of a sudden a (injector spraying fuel) light on the dash lit up RED and the car began to die.
I threw her into 3rd gear to pick engine speed and revs back up, then back into 4th for the same to happen again. i repeated this as it worked enough to get me home! Since then it the engine starts but seems to hunt and occasionally cuts out, you can rev it right up and it seems ok (fast idle) 2500-3000 revs, let throttle off and it dies...so it has fuel and spark any ideas will be greatly appreciated
Thanks in advance, Lee
My thoughts were possible coil pack & leads or idle control module if it has one!
