Technical Cinq Trofeo
bozothenutter
Den Haag
Are the Cinq trofeo parts available through fiat dealers (if there are any left).
Were they ever in the catalog?
I remember working at Renault ages ago where you could order all the racing parts through the normal catalog, even whole chassis with cage!
Simple answer is: No, you will not get them from a dealer.
There was a parts book, I've seen some on ebay before, but were not in english.
I don't think you will ever get any parts now, unless you bought a trofeo car with spares
example here
wow, has anybody ever taken the trouble to scan this book, I read german and would love to read about the mods made!
Especially to the engine, I think it was 90bhp with a special ecu and a 10:1 compression ratio.
would that be doable on any 899, increasing the compression?
You need to be careful about what you read. There was more than one Trofeo series. The original was for 899 cars, but they changed to 1108 later on. The specification was set so that they would all be the same power, and not too expensive.
There was also a Group A car homologated for International use which had nearly 110bhp from 1108.
SPD
I have a original 899/903 Trofeo from 1994. It has approx. 65 hp with special ecu and a 10.45 compression ratio.
I am sure you can get more than 90 hp out of this engine. Abarth used to do it on the 600 based cars.
But if you do, then it really wouldn't be a Trofeo, would it ?
The details I found on the two cars are;
ENGINE
903cc & 1121cc
Bore×Stroke(mm) 65.0X68.0 # 70.4X72.0
Max.Power(bph/Revs) 65/7000 # 90/7250
Max.Torque(kg-m/Revs) 7.9/4000 # no data
No.&Position Cams 1ohv both
DRIVE TRAIN
Differential Mechanical
Clutch Metallic
No.Plates 1
Gearbox No.Foward gears 5-Syncro
BRAKES F/R
Gravel F/R(φ=mm) Asphalt F/R(φ=mm) DV240/Drum185
SUSPENSION
Front(Shock Absorbers) McPherson(Bilstein
Rear(Shock Absorbers) Trailing Arm(Bilstein)
DIMENTIONS
Length(mm) 3227
Width(mm) 1487
Wheelbase(mm) 2200
Weight(kg) 760 (later 1121cc car 791kgs)
HOMOLOGATION
Date of 1st Homologation 1 October 1992 for 903cc 1 January 1995 for 1121cc
Homologation numbers; A5463 & A5529
Parts were available from Fiat dealers when they knew how to use the eper.
It is unlikely to get most of the parts now if any at all as the production of the Cinquecento seized 11 years ago, which means the manufacturer doesn't have to provide the parts anymore.
my mate owns and rallys a original 1108 Trofeo. Ill email him later for some photos and details on it. he went to Italy to buy it and suposingly it does got like stink
Hello all and Craig ,,,,,,,,,,,, yep it go`s well some photos for you ,,,,,
out side of Fiat Auto Corse
