Technical Cinq stalk pin out anyone?
Has anyone got a known good pin out for the steering column stalks of a late Cinq (not with Sei stalks though) I've managed to get 6 of the 13pins but I can't get any response out of the rest no matter what I do with the stalks :(
Do I sense youre retrofitting Sei dials to a Cinq?
I think there may be a couple of constant lives in there and a few earths.
Not the dials but the stalks, I find the Cinq ones a pita to use.
My problem is I've got a wire colour refrence that doesn't quite match up to the loom coming into the Cinq stalks so I duno how much I trust this -
Code:
Colour                        Description
Black                         Horn +ve Out
Grey/Black                    Horn -ve In
Light Blue/White              Wiper Intermittent out
Orange                        Wiper Out
Orange/White                  Wiper In
Green/Black                   Washer motor Out
Green                         Power In
Grey & Yellow                 Main beams signal (seems redundant, flashers?)
Blue                          Main beams out
Light Blue/Yellow             Main beams ignition in
Light Blue                    Offside Indicator Out
Light Blue/Black              Nearside Indicator out
Orange/Black or Purple/White  Indicators Power In
Electrically though this correlates well with the Sei stalks
Bugger, thats what I meant. Im gonna retrofit a set some point soon too.
As for pinouts, you may be best off tracing it from the sources or the 'cut and hope' method
When I retro fitted later Cinqs (Sei) stalks in a earlier type I just used trial and error to get everything to work, didn't take long, few hours at most. I found that as the earlier Cinq has the headlamp switches on dash you end up with IIRC 3 wires that do nothing as the later type stalks do not need to run wires from column to dash and back because you still need to get full beam/flash through stalk.
