ilsonemo Speed Camera Tester Joined Dec 6, 2007 Messages 563 Points 263 Location Ilkeston (Derbyshire) Mar 18, 2008 #1 Rite hears my problem, i have a cinq sporting that has a buggered crank sensor, i also have 2 900cc cinqs as a donor cars, can i use the crank sensor of the 900's and put it on the sporting ?
P pingu fia Parked in the garage Joined Jan 16, 2008 Messages 242 Points 68 Location birmingham Mar 18, 2008 #2 no. you need the proper 1.
OP OP ilsonemo Speed Camera Tester Joined Dec 6, 2007 Messages 563 Points 263 Location Ilkeston (Derbyshire) Mar 18, 2008 #3 how much is a crank sensor for a 1.1 then ?
fingers99 Patron member Parked in the garage Written a guide Joined Mar 20, 2006 Messages 27,743 Points 4,561 Location Liverpool Mar 18, 2008 #4 I'm pretty sure the 889 one will work on the Sporting: you may need to extend the wiring or change the connector. Why not give it a go? ePer (above) should give you an idea of how much a new one is, probably get one cheaper from Flffy the Impaler (on ClubCento) or Shop4Parts.
