If yours is located just forward of armrest behind handbrake plastic...then when I did mine I just pulled the covers off in the footwell only takes a minute or two to remove and put back you can also just remove handbrake cover only clips in place if needs be, then you can wiggle your fingers through to pull connector of the socket., connect new check works and replace the panels in the footwell or handbrake cover if removed,,, if you happen to blow a fuse then that can be found in the fuse board in cabin to lower right of steering wheel no idea off hand which fuse number it is, but with luck you not need to know at this time.
