ok, done the head gasket and head
the cam is worn/or need the shims doing
when driving the car feels ok, but its chugging like mad at idle, this, and the fact than in just 15 miles of driving, its used a shed load of fuel, a tad less than a 1/4 of a tank
I took the airbox off to check the connections to the injector unit, I did this with it running to see if anything made a difference, the throttle position sensor didnt make any difference when unplugged and plugged back in, neither did the connector [intake temp?] when undone and put back in, the plug at the top/back of the spi unit made it die when undone.
I also pulled the vac pipe off the map sensor, not much difference, and not much with its connector undone either
I didnt disturb any other connectors anywhere.
any ideas?
any ideas?
