JordanCroma
- Joined
- Oct 31, 2019
- Messages
- 3
- Points
- 1
Hello , Its me Jordan ,
Im owner of a Croma 2007 year 1.9 diesel 150 hp automatic gear box.
I few days ago i was driving in the traffic when i get a warning light about my engine temp. It was all the way in the red,but the car was running properly.
I did move away from the road in after 10 meters and cut the engine off.
While i was on my way to stop my window was open , and there was no fan noise coming from the front. Anyway i was like 20 more meters away from my home, so came back to the car in the next day and move it in my home parking lot.
The stat of the car is recently changed with a new part and in my opinion it works rly good. There is also brand new cooling liquid + new water pump ( the water pump is giving me a really nice flow i can even see that in the coolant reservoir.
I start to dig for the problem and on the first glance i told there is a Cooling fan issue. I did test the fans , while providing them with 12v and they both starts.
So o told my self i have to test are the fans are working at all. I unplug the coolant sensor connector , then i start the car and only the climate fan starts working.
Since i know that both of them are working, i decided to make a relay check.
They where all working correctly, and so the fuses are in perfect shape too.
What should be my next step?
There is a control module located in the top of the fan housing, how can i test is it working properly?
Do i miss something while testing this?
Many thanks , from Bulgaria !
