Technical Checking/changing dualogic g'box oil
Pandaconvert
Hi
I'm new on here having joined to hopefully get guidance on how I can check/top up/change the oil in the dualogic box. I posted this enquiry on the Panda thread (as that is what I have) but gather this side of the forum is more active and the gearbox is the same. The car is now 6 yrs old / 34k miles and looking at the service history (main dealer) I can see no reference to it being changed. The gear change is becoming more laboured in auto mode so what to prevent any greater issues arising.
I'm doing a 'service' myself this time around and want to include the gearbox - but how??
Grateful for help please
Hi
If its not leaking I would not worry ,if you check the level it will appear low because the selespeed fluid that is used in the dual logic system is not all in the bottle you need the diag equipment to depressurise the system as some is still in the circuit.
There is no service change for dual logic nor the gearbox oil
Thanks for this. I am going by the service schedule that states it should be checked every 20k. As the car has only had 'low miles' services it doesn't appear to have been checked (from the dealer check sheet).
