Hi all,
I can see from this forum that I’m not the only one with this problem!
The car has very low mileage (9,700) for a 2016 model and generally used for local driving and not much in the last year! My problem started in May last year when the check engine light came on and the car went into limp mode. Restarting the engine solved the limp mode problem but the check engine light stayed on. This became an intermittent problem.
So I booked the car into a local Fiat specialist (not main dealer) and the diagnostics showed no problem and it seemed to fix itself but in
January this year, the problem reoccurred and this time the pressure sensor had a fault and was replaced. Only worked for a couple of weeks, booked in again and air leak from inlet manifold gasket detected. Part replaced and the car has been running ok for the last 3 week.. until today.
Car has been serviced and MOT’d.
I’d be grateful for any advice. Thanks.
