My 2007 2.3 Ducato is not charging, when I check the supply to the alternator it is only 9V, is this correct or is something dragging down the voltage?
B+ is the thick cable that connects to the battery to charge it via the starter motor.
D+ is the output that extinguishes the battery lamp when the alternator starts, as D+ goes negative. This voltage comes to the alternator via the Body Control Module
I thought modern alternators have the exciters built in to their voltage regulators??
PS. Does it start to charge if the engine revs are increased?
