H Hatch New member Joined Feb 1, 2010 Messages 1 Points 1 Feb 1, 2010 #1 Hi, any tips on how I go about this, Do I need to get new casing for the unit? if so, where from? Do I need to go to a Fiat garage for this, Thanks in advance H.
T14086 Patron member Written a guide Joined Sep 12, 2004 Messages 39,826 Points 7,252 Location Preston Feb 1, 2010 #2 fiat dealership will have/get you surround for the standard size (DIN) aftermarket stereo you want to fit.
M malcolmgb New member Joined May 10, 2008 Messages 40 Points 12 Location Midlands Mar 17, 2010 #3 You probably have done this by now, but the metal cage which came with the stereo fitted in the Fiat 'DIN' hole, the main problem is with the two 12v feeds Fiat only use one of them, the solution is to be found elsewhere on the forum.
