Simple job. Leave the battery disconnected for at least a couple of hours for the airbag to settle before you start. you may be lucky and get away with the airbag light intact. if it is still lit when it is re-assembled then it will cost about £20 to have it re-set
doggy bag?? would removing the fuse stop the airbag light coming on? would it be ok to test ive taken the correct fuse out by switching the ignition on obv with the steering wheel on
